Problems with new version (9.0.5.0)?
Ander
Post by Ander »
I've updated to v9.0.5.0, and have found some problems:
• I can't vertically resize the window to less than 2/3 of my display height. (It's still resizable horizontally.) I have only a few backup profiles, so most of SBF's window is now empty, and covers other open windows.
• The "Modify" command seems to have been removed from the context menu (see screenshot 1). Was that an oversight, or is there a different way to modify profiles now? (I couldn't find one.)
• Some of my profiles no longer show their complete folder paths, unless I hover over them (see screenshot 2).
• Pretty minor, but: When you open Global Preferences, then close the window (either by clicking "X" or Cancel), a warning appears: "The changes you have made will be lost. Are you sure you want to continue?" Sorry—what "changes"?
I'm also somewhat disappointed to see you've switched from standard menus to the Microsoft-style, horizontally oriented "ribbon" GUI, where each command has an icon, takes up much more space, and takes much longer to look through and use. I realize some people like this simplified approach—but to those of us used to compact, efficient menus, it seems like a step backwards. Any chance you could include an option to revert to standard menus?
Thanks!
Ander
Re: Problems with new version (9.0.5.0)?
Post by Ander »
I was going to add that I hadn't used the new version yet... It was such a surprise seeing these apparent oversights, considering your usual high coding standards, I'm worried there may be some problems with the app's actual functionality. :?O
There's no way to edit our own posts here, though? Or was I just unable to find it?
Ander
Post by Ander »
Oops, I forgot those screenshots, too—here they are. (No way to add them to my original post?)
Ander
Post by Ander »
Until you can get to this, is there any way I can re-download the previous version, which didn't have these problems?
Post by mickyj »
Ander wrote:
Wed Jun 12, 2019 10:04 pm
Hi, there's a minimum height, which is why you can't reduce it past a certain point. For the next release the minimum height is lower.
I think this is because your screen height is low, so it's removing menu items to reduce the pop-up menu height (so it can fit on the screen). As you've hidden the button panel (which has run, modify, etc) then this is obviously going to be a problem. Until the next release, you'll need to restore the button panel (via the burger menu->Preferences, at the top-left).
The text simply doesn't fit in the space, so the tree shortens the string as best it can. This is no different than in V8. V9 has a slightly larger font, so maybe all you need to do is increase the column width.
There'll be a default value that hasn't been saved. I'm pretty sure V8 (and earlier versions) act the same, i.e. if there is a new global setting, and there is a default value, then you'll get the same until you save the settings. We'll take a look and see what setting it is and so avoid this.
No. We won't be reverting to standard menus.
