Scheduling every xx minutes
PeterDr
Post by PeterDr »
Working on a Win 10 computer, as the destination, connecting to a win 7 computer which currently hosts the folder I wish to copy every 30 minutes. I am using SyncBackPro V 7
How can I set up a profile in the scheduler to run every 30 minute?
It is set up to Run this profile every 0 days 0 hours 30 minutes 0 seconds
for a duration of 30 days 30 and click OK
The schedule then appears with
Schedule
Every 1 days, repeating every 15 ninutes for a duration of 30 days,
If I click ok ion t, the project will not run until the following day., then I suppose -- once per day for the next month
How can I set it up to run every 30 minute, beginning immediately?
Than you for your help.
Peter
Re: Scheduling every xx minutes
Configure the profile to Recur every [1] day and Repeat setting as:
Run this Profile every : [0] days, [0] hour, [30] minutes, [0] seconds
for a duration of : [0] days, [23] hours, [30] minutes, [0] seconds
Do not enable the 'Indefinitely' option.
PeterDr
Post by PeterDr »
Aha! Excellent!! Thank you very much.
This will help me to keep data from several programs that I access from several computers synced with each other. This brings the Pro into the Sync. : :D
BS_Wingfield
Post by BS_Wingfield »
I have a similar problem, I want to run a backup every 2 hours but only between 7 a.m. and 7 p..m every day, could someone help me to set this up?
1. Modify profile > Expert > When > Edit Schedule settings page
2. Click on Daily tab on the top
3. Configure the Start Date, set the Time as 7 am and 'Recur Every' setting to [1] day
4. Click Settings tab and tick 'Run this profile every' option
5. Configure the Repeat Interval as:
Run this Profile every : [0] days, [2] hour, [0] minutes, [0] seconds
for a duration of : [0] days, [6] hours, [0] minutes, [0] seconds
6. Do not enable the 'Indefinitely' check box
7. Save the settings
BS_Wingfield
Many thanks for your suggestion, I had my options setup in a very similar way but the job would run outside the prescribed hours.
BS_Wingfield
I tried your suggestion but am still having the same problem:- The job still runs outside my requested hours.
Can you export and send your profile configuration to [email protected] for investigation.
BS_Wingfield
Posted offending profile
Janeo
Post by Janeo »
Swapna wrote:
Fri Mar 13, 2020 5:35 am
a) Configure the profile to Recur every [1] day and Repeat setting as:
b) Run this Profile every : [0] days, [0] hour, [30] minutes, [0] seconds
c) for a duration of : [0] days, [23] hours, [30] minutes, [0] seconds
d) Do not enable the 'Indefinitely' option.
I do not agree. The c) should be:
for a duration of : [1] days, [0] hours, [0] minutes, [0] seconds
And then it works :-)
Untitled - 1.jpg (98.5 KiB) Viewed 13605 times
