It would be very great to have an option to « pin/unpin » the filter tab (as in Office for the display of the content of the tabs) of the differences screen when you run a profil. Frequently, you need to see only modified files or only suppressed files and it would be directly available with this option.
In the same way, it would more ergonomic to rearrange the filters in order to show in the same column the same type of filters like in attachment (sorry it is in french)
Thank you if you can add this feature in a new release
Request in difference screen
7chervet
- Image.jpg (84.22 KiB) Viewed 11511 times
