ow do i set several routines to run in order
frankraney
Post by frankraney »
I have 5 routines. How do I set them in a group to run in a specific order?
Re: ow do i set several routines to run in order
Uncheck "Run Profiles in Parallel (at the same time)" and then in the right box move your profiles to be in the order you want them to run.
frankraney
SOLVED....
