On one particular set of directory/files I consistently get a Failure message when backing up.
This, despite the fact that new files are copied across correctly and existing files ignored as expected.
Other directories /files backup without any problems and give a successful result.
I cannot find a D:\Recovery directory on the drive. Should there be one or is it only temporary ?
Tyke
Repeated failure ...apparently
Tyke
- Capture1.JPG (60.04 KiB) Viewed 5495 times
