Error explanation
needowelum
Knowledgeable
Knowledgeable
Error explanation
Post by needowelum »
Every time I back up my documents, I get the same error
_SyncBackFree V10 Log_2022.03.24.png (32.41 KiB) Viewed 8310 times
_SyncBackFree V10 Log_2022.03.24_2.png (11.78 KiB) Viewed 8310 times
However, I can manually copy and paste the file to the destination.
Is this due to some security issue related to the functioning of Teamviewer?
christkenddy
Re: Error explanation
Post by christkenddy »
needowelum wrote: ↑
Thu Mar 24, 2022 11:14 pm
_SyncBackFree V10 Log_2022.03.24.png]
Depends how you've set it, you can choose the behaviour when it sees a file that already exists, it can chack size and last modified time, if it sees those are the same it will skip it by default.
needowelum
Knowledgeable
Knowledgeable
christkenddy wrote: ↑
Thu Apr 21, 2022 12:09 pm
Here are my settings. The same for all of my profiles.
This backup task is for my entire "My Documents" folder. This file I mentioned is the only one that gets flagged.
christkenddy
needowelum wrote: ↑
Fri Apr 22, 2022 7:37 pm
let me do some search and I will come back soon with a solution...
