SyncBackPro detecting .JPG files on Egnyte as if they were folders
hdadmin2022
Post by hdadmin2022 »
I'm using the "sync to destination" type job but I noticed that my destination (local folder in WIndows 10) is missing files. I did some spot-checking manually and found that a lot of JPG (and at least two PST) files were detected as being directories/folders instead of the JPG/PST files they are. In another folder, the PST files copied down correctly, so I don't know why they're not copying here. Below is a screenshot of what Egnyte shows. The logs don't even mention these files. Is there a way to fix this?
Screenshot 2022-08-04 120633.JPG (176.59 KiB) Viewed 4930 times
